Can I Replace SLI16-1 with SLI16-2
If you are looking for some parts, or selling some Alcatel stuff, this is the place !
adnaninline
Post by adnaninline » 06 Jul 2017 17:20
Hello All;
I am replacing a "MIXED" card with "SLI-16". I ejected MiXED card and inserted SLI16-1 and It was detected by the Cabinet easily. I do have some cards that are SLI16-2 but when i insert this, it is not detected by the system. My Software version is 3EH30382ARAA ALZPK610/007.004. Is it due to version of the software and do i need to update the OMC software to detect this SLI16-2 card or is it not compatible with my OXO. I want to replace the card because of faulty ports.
Prompt reply would be highly appreciated.
Kind Regards;
Adnan Alam.
enio.eltz
Re: Can I Replace SLI16-1 with SLI16-2
Post by enio.eltz » 07 Jul 2017 06:37
Upgrade the software to the latest R6. R610_007.004 can't recognize SLI16-2.
Best regards.
Enio Eltz Filho
ACFE OXE R12/R11/R10
ACFE OXO CONNECT R2
ACFE OXO R10/R9
adnaninline
Post by adnaninline » 08 Jul 2017 14:25
Hello;
Thank you Enio.eltz for the reply. If you can please help more then What are precautions of the upgrade? What step should i take to remain on safe side if something goes wrong?
Kind Regards;
Adnan Alam.
enio.eltz
Post by enio.eltz » 10 Jul 2017 06:46
Be sure I have done a backup with the latest OMC.
Besy regards.
Enio Eltz Filho
ACFE OXO CONNECT R2
ACFE OXO R10/R9
adnaninline
Post by adnaninline » 11 Jul 2017 16:57
Thank you enio.eltz
Return to “PARTS”
