system date/time
orangebusiness
system date/time
Post by orangebusiness » 23 Dec 2011 04:42
by which command i can change the system date/time?
Re: system date/time
Post by vad » 23 Dec 2011 04:54
or mgr - go to System and change.
or swinst/expert menu/system management/date and time management
FN_DK
Post by FN_DK » 31 Dec 2011 06:10
I strongly recomend that you configure an NTP server. Then you Will always be "up to date" :lol:
Happy new year
Ayman
Post by Ayman » 08 Mar 2012 09:45
Hi All,
How can I change the Time format from 24 format into 12 AM & PM format?
Thank you all
Ayman
sven
Post by sven » 21 Mar 2012 06:24
Ayman wrote:Hi All,
For what? Do You want 12 format for the phones or for your console of oxo/oxe?
Greetings Sven
idtasov
Post by idtasov » 02 Apr 2012 09:45
I have strange problem with time adjusting, if set time with 1-way - system ..... it roles back with previous setting ?
murraya
Post by murraya » 02 Apr 2012 15:35
check if NTP server is running or maybe you have network time update set on the trunks under shelf/DH/Board/DH/Digital accesses.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
idtasov
Post by idtasov » 03 Apr 2012 01:51
NTP is running on local host and I stoped all time synhronizations from trunks. The strange is that from system menu the time is 15:30 and from swinst is 16:30 in same moment
Ayman
Post by Ayman » 05 Apr 2012 04:25
sven wrote:
Ayman wrote:Hi All,
Greetings Sven
I'm asking for Date/ Time format 12 AM/PM for the users Telephone sets screen
Thank you all
Ayman
Post by Ayman » 05 Apr 2012 08:59
Thank you sven for your answer,
I want to know how to change the format of the Clock on the users telephone screen into 12 AM / PM format instead of 24 format?
Return to “System”
