BC unrestricted/speech
donbru01
Post by donbru01 » 05 May 2017 10:24
Dear guys ,
On ISDN PRI provider, send me BC unresctricted for each call ( also for speech call ) , but i must via DDI redirect this to analog device .
Actually PBX answer to provider destination incompatible
There are a chance to manage PBX that accept call BC unresctriced towards device analog
Thanx in advance
donbru01
Re: BC unrestricted/speech
Post by donbru01 » 09 May 2017 12:08
No answer ???
sadim
Post by sadim » 09 May 2017 12:54
If you check TC0730:
- unrestricted digital data support (this is digital data from end to end - code 88 90), a call with data support request can only be routed to a data end device
alex
Post by alex » 10 May 2017 03:51
If you set in Specific Telephone Services/Phone Compatibility/Fax Group 4 = 1 will it work?
Anyway, your provider'd better comply with ITU Recommendations and set right BC for calls.
donbru01
Post by donbru01 » 10 May 2017 03:56
Dear Alex , yes it will not work
Fax Group 4 Compatibility x
x x
x Phone : 1 x
x Fax Group 3 : 1 x
x Mixed Teletex : 0 x
x Fax Group 4 : 1 x
x Teletex character : 0 x
x Videotex Mosaic : 0 x
x Videotex Inter : 1 x
x NPI/TON: Telex : 0 x
x Msg.Handler Syst.(X400) : 0 x
x ISO Application : 0 x
x Audiovisual : 1 x
x Unknown Teleservice : 1 x
x Audiography : 0 x
x Audio-videotex : 0 x
x Non-standard Application : 1 x
x Teletex Base : 0 x
x Reserved Maintenance : 0 x
x Reserved System : 0 x
x
alex
Post by alex » 10 May 2017 04:25
That's bad. Use digital set or ask your provider to supply right BC for calls to analog sets.
donbru01
Post by donbru01 » 10 May 2017 04:34
Dear Alex , you have right . But on analog sets we have a particular modem ADEMCO 685 for receive alarm busrt 16 DTMF 50ms/50ms .
Provider in Italy has switch backbone on VOIP and it send abnormal DTMF ( issue on dtmf detect ) on my PRI , lost half dtmf sending
Than we have try that if Provider manage your backbone on clear-mode all work fine but it must send me bearer capability "unrestrited digital "
Return to “System”
