Default IP a4400
omarsg1977
Default IP a4400
Post by omarsg1977 » 03 Aug 2017 11:51
Hi, i need to know witch ip is configured by default in a4400.
Re: Default IP a4400
Post by cavagnaro » 03 Aug 2017 11:58
Why? If you install it you will set the IP ADDRESS as one of the first steps
omarsg1977
Post by omarsg1977 » 03 Aug 2017 15:20
A cliente call me to make some changes but i can't connect by v24 and the ip is by default, the client don't use the ethernet connection.
mgoegel
Post by mgoegel » 04 Aug 2017 01:25
I have seen different default values in the past.
Maybe 10.253.253.1 or possibly some 192.168.x.x which I don't remember right now.
Is the OXE connected to the lan? If yes, the subnet of the customer could give you a hint. If the customer really never connects via IP, then it could be anything, depending on the installer.
So your only chance could be the V24 connection.
Regards Mario
Gesendet von iPad mit Tapatalk
omarsg1977
Post by omarsg1977 » 04 Aug 2017 02:02
Thank you so much
Enviado desde mi iPhone utilizando Tapatalk
Return to “System”
