Continuous Resetting of EZ32 board
timbrown
Post by timbrown » 04 Feb 2016 23:36
I had a problem whereby an analog board EZ32 on a peripheral shelf has been resetting continuously. I've swapped out the board with another and its working but I'm curious as to why that occurred. Does it have anything to do with the disruption on the fibre link???
Re: Continuous Resetting of EZ32 board
Post by vad » 05 Feb 2016 01:40
You have only one board in the shelf?
If you have problem just with one board (other boards work, no problem with INTOF) - I think your eZ32 board broken (f.e. some problem with power supply circuit on board).
In my practise was case - board was inserted not good - sometimes was incident, restart. When board was removed and inserted - problem disappeared.
timbrown
Post by timbrown » 07 Feb 2016 15:41
No, I have other boards in the shelf. I've just tested that same analog board and its working fine. My concern was why it happened. Maybe it just needed a hardware reset.
Return to “Shelf”
