UA 32 BOARD
sapostolou55
UA 32 BOARD
Post by sapostolou55 »
HI
Difference in BOARD UA32 3BA53050ABAB 03 and in 3BA53050 ABBC 01 ????
Konstantinos.E
Re: UA 32 BOARD
Post by Konstantinos.E »
Hello ,
I suppose there is deference btw electronic parts.
Alca_holic
pbxports
Re: UA 32 BOARD
Post by pbxports »
Sorry to raise an old post, but does anyone know the difference between an Alcatel UA32 with following part numbers. 3BA53050AB and 3BA53050BA
Customer asked for BA but we only have AB
Re: UA 32 BOARD
From TC 0418 ed02
84. UA32 BOARD- 3BA53050BAAA
ICS 01
Creation of UA new UA32 board for improve CEM compatibility in the frequencies 2MHz to 50MHz.
ICS 02
Bad reference of quad into part list.
Some improvement. Usually was no problem with UA board
pbxports
Re: UA 32 BOARD
Post by pbxports »
thats great, thanks for your help
So they can use AB or BA without any issue?
Eliott
Re: UA 32 BOARD
Post by Eliott »
Yes
tgn
Re: UA 32 BOARD
Post by tgn »
beside this:
what about the UA32NV Board (3BA23079AB)? Is it possible to connect CCD Agents with NOE Phone sets on this board?
Does someone has some experiences with this?
regards...
Eliott
Re: UA 32 BOARD
Post by Eliott »
As far as I remember eUA board is needed.
tgn
Re: UA 32 BOARD
Post by tgn »
thanks for answering!
this is what i‘ve found out:
the ua32nv is loading the same binary like an eua32.
the board description says:
Alcatel UA32NV Dig Ext Card Item ID: 3BA23242AA Description: Alcatel UA32NV Digital Extension Card to Suit Alcatel 4400 OMNI.
Advanced features from the UA32 include: New transmitter/receiver
called OSIRIS (Octal UA transmitter/receiver), a new UA interface
from the QUAD UA transformers and a new CB8 p/s.
i am not sure with this, but i thought i have done connecting ccd noe phones in the past on a customer site (but didnt remember the boards number... and it looks like a normal ua32 on the frontside, only the article number is different.)
on the downside i‘ve no ua32nv board for testing at the moment.
maybe someone have some board for testing (or has tested this).
regards...
Eliott
Re: UA 32 BOARD
Post by Eliott »
That is a normal functionning. that is not allowed to create a proacd phone set 4039 on old UA32 boards. No development is planned to support NOE set on old UA32 board. You have to use and declare the proACD 4039 on UA32NV.
Official ALE statement in year 2007
You're right. eUA32 and UA32NV are the same except licensing.
UA32 is old and not supported.
Return to “Shelf”
