I tried installing 8232 on OXE R10.1 with IP DECT. The documentation says it's compatible but I can't get it to work properly :
Registration seems OK but then I can't do anything. It's like "frozen"... I can't dial or press any key.
Others phones are working fine (I use Gigaset).
I put RBS and "IP Base Type" to Yes in OXE. I've installed DAP Controller v6_00_117.
I created users as SIP Extension. Documentation says that 8232 are working in AGAP mode (should be declared as GAP+) but when you set "IP Base Type" to Yes, you can't create GAP+ sets anymore...
Did anyone have the same issue before?
Thank you for reading!
