Dect 300 on OXE and OXO
red_monteiro
Post by red_monteiro »
I have a dect 300 registered in the OXE and need to register simultaneously in a OXO as System 2. You can register in two different systems?
After register in the second system (OXO) , lost the register of the first .
Thanks.
Re: Dect 300 on OXE and OXO
Not use autoinstall feature.
Select "installation" from menu and install f.e. for OXE in System 1 and for OXO in System 2.
red_monteiro
Hi.
sorry, i don't understand when you say "install f.e."...
That was what i did:
that's what I did: with dect deregistered in oxo, clicked on the OK button , navigation button to the right , ok button , system 2 , install , launch subscription , region 3.
Is correct ?
If DECT registered in OXO in System 1 - Ok, you can register DECT in OXE in System 2. If DECT registered in OXO in System 2 - no.
red_monteiro
It was solved with dect 8232 registered in OXE and OXO in register 0 and register 1.
thanks!
Return to “PWT/DECT System”
