Incoming Alarms are not detected in DECT 500 (IP dect)
kart_eee
Post by kart_eee » 10 Mar 2016 08:56
I have alarm server configured with OXE R11.2 (l2 300 25 c) in IP DECT environment.
Incoming emergency alarms "C~" to the DECT 500 is not detected in the phone firmware . This message is detected DECT 8242 firmware properly.
Please help me out
IP dect DAP configuration version is R6.00.0010
DECT 500 Fw 10.84
sadim
Re: Incoming Alarms are not detected in DECT 500 (IP dect)
Post by sadim » 11 Mar 2016 15:38
Please check in the DECT set:
settings -> Security -> Alarm settings -> Alarm server -> server settings
if Urgent Alarm "C~"is managed
Also check in the DECT set:
settings -> Security -> Alarm settings if it is set to Off.
If it is set to Off, change to "Force ringing is set to "Ring".
Return to “PWT/DECT System”
