8232 handset battery compatibility
audi a600
Post by audi a600 » 21 Nov 2016 01:52
Nokia BL-5C battery has the same dimensions and parameters as in 8232 handset original battery (3.7 v, 1100 mah).
Is it possible to use well-known Nokia battery instead of original? Are these batteries fully compatible?
Thank you in advance, Evgeny Chernov
Re: 8232 handset battery compatibility
Post by vad » 21 Nov 2016 05:22
Try to send you PM but new user can't read private message.
My suggestion - take one battery and make test - autonomy time, charging time etc (or try to remove label on Alcatel battery, may be you will find "nokia" :lol: ) . If Ok - use (and say to us :)
Return to “PWT/DECT System”
