DAP Controller with Asterisk
giovanni.attolini
Post by giovanni.attolini »
"friday morning thougths"
Someone have tried DAP Controller plus 8340 using Asterisk or other softswitch like gatekeeper?
Is or can be IP Dect a pure SIP solution?
thanks
Giovanni A. Attolini
alex
Re: DAP Controller with Asterisk
Post by alex »
giovanni.attolini wrote: 05 May 2017 07:39 Is or can be IP Dect a pure SIP solution?
It is just a pure SIP solution - just like any SIP-gateway.
giovanni.attolini
So, I am trying register some users on asterisk and even after SIP register, DECTs still remain without operation.
Have you any experience registering IP DECT in other systems?
Can you give me some help configuring DAP Controller to this scenario?
mgoegel
Post by mgoegel »
Ohh, it's not plain sip, there are much sip info messages sent I.e. From OXE to dap(/controller).
I don't know, if you could bring the asterisk sip channel to send that amount of messages on the registration.
You should take a trace on OXE and play a little bit...
Regards Mario
Gesendet von meinem F8331 mit Tapatalk
alex
Post by alex »
mgoegel wrote: 09 May 2017 12:37 Ohh, it's not plain sip, there are much sip info messages sent I.e. From OXE to dap(/controller).
May be it depends on which binary is loaded to DAP. At least there are two binaries available - native (NEC) binary and ALU binary. From DAP documentation you need only SIP registrar and SIP proxy configured in DAP for it to work.
giovanni.attolini
Ok.
What binary is related with pure SIP solution?
Is this binary available on BPWS?
alex
Post by alex »
On ALU site only alcatel's binary is available.
giovanni.attolini
How I can get another binary?
Return to “PWT/DECT System”
