DECT To DECT Call Problem
energydat
Post by energydat »
Hi all,
We have a User with around 32 IBS DECT Stations (some 3 Channel, some 6 Channel) and an OXE Running R11.2.032a and around 130 DECT Phones (Mobile 300, 8242...)
Problem:
I make a Call from DECT to DECT. The caller Set rings 2 Times and Release the Call with "Not possible" Same when Calling Set is UA Or Z.
I only Knew this Problem when the DECT Set is out of Range.
But the Set is in good Range and the IBS Station is Running well. No issues on incvisu.
Does anyone have Same Problems?
So please let me know how i can Check what is Happening...
Commands to trace the Call?
Is there a command to See which DECTS set are on which Station in real time?
Thank you
Gesendet von iPhone mit Tapatalk
Re: DECT To DECT Call Problem
about command - dectview
dectview ibs, dectview com (etc)
I know another problem (except Out of range)
- many people nearby DECT base station with 3 channel :)
- problem with synchronization (when IBS DECT stations connected to different IP MG)
tgn
Post by tgn »
maybe dectobs give you some information.
regards...
energydat
Post by energydat »
Soved it.
The Problem was in duplicated configuration.
After switching to CPU B, everything was fine.
Switching back to A Problem the same.
Did master copy B to A and all was good on CPU A.
IN incvisu i saw, that CPU installed after mastercopy a patch...
Very strange....
Return to “PWT/DECT System”
