Block an incoming call from particular DID
tjm0852
Post by tjm0852 » 11 Feb 2010 13:08
I have searched this post http://old.alcatelunleashed.com/viewtop ... ming#p9608
and looked at R9.0 documentation but I cannot figure out how to block incoming calls from a particular DID.
I want calls from 123 456 7890 to go to VM announcement, stating the call cannot be completed as dialed.
Can anyone give me a hand please.
JoelO
Post by JoelO » 11 Feb 2010 14:14
It's under ( OmniPCX Enterprise 9.0 / General Applications / Caller / Called filtering ) .
tjm0852
Post by tjm0852 » 11 Feb 2010 14:44
Found that, but it might as well be in Japanese. I am having any issue creating the Caller Number Filtering within the speed dial range.
Eliott
Post by Eliott » 12 Feb 2010 05:57
The to be filtered caller number 123 456 7890 has to be managed in speed dial area:
Consult/Modify: Abbreviated Number
Range Number : 1
Abbreviated No. : 00
Call Number : 0123 456 7890
Go down
Consult/Modify: Caller Number Filtering
Range Number : 1
Filtering index : 1
Routing Number : 1000 <- your target DN
mtcl
Post by mtcl » 12 Feb 2010 07:41
Here is a step by step configuration
tjm0852
Post by tjm0852 » 12 Feb 2010 13:50
OK here is what I am doing.
Translator => Filtered Called Number => Create
Directory Number: A2345
Entity: 10
Public Rerouting: False
Then in Teleservice filtering
Directory Number A2345
ISDN Teleservice + Phone
Status + Day
Filtering Index: 0
Overflow Directory Number: 22825
This is as far as I can get, from here I have tried 50 different things in the speed/abbreviated dialing are only to be met with object instance errors.
Can anyone help me along further?
Eliott
Post by Eliott » 12 Feb 2010 15:32
First of all the caller has to dial the A2345 via the DDI Translator.
The other management looks okay if you need NO filter for the caller. Is entity 10 in day?
But you wanna filter the caller - so you have to manage the abbreviated number for filtering index 0 as described by me some posts before.
swinstation
Post by swinstation » 23 Mar 2010 06:18
you can give another COS and disable everything on it.I did it for one of my site when external caller dial 84842000(direct manager extension 2000)hears busy tone.you can block all of incoming call on cos.i hope it be useful.
swinstation
Post by swinstation » 02 Apr 2010 12:49
let me know the result please
ozlemguven875
Re: Block an incoming call from particular DID
Post by ozlemguven875 » 06 Jan 2011 10:40
I tried call filtering from a specific external number 4554000 to 4552001 ,but it didn' work.Can you help me ?
my configurations:
Node Number (reserved) : 1
Instance (reserved) : 1
Range Number : 5
Speed Dialing No. : 10
Call Number : 04554000
Directory name : --------------------
Directory First Name : --------------------
UTF-8 Directory Name : -------------------------------------------
UTF-8 Directory First Name : -------------------------------------------
Call Restrictions - Barring + False
Overflow Range No. : -1
Auto.Attendant Calling Right : 0
Call Type + Normal
Timed Overflow Range No. : -1
Can be Called/Dialed By Name + NO
Displayed Name : 4554000
External DISA Dir.No. : --------
┌─Review/Modify: Caller Number Filtering─────────────┐
│ Instance (reserved) : 1 │
│ Range Number : 5 │
│ Speed Dialing No. : 10 │
│ Filtering index : 111 │
│ Routing Number : 2002 │
┌─Create: Filtered Called Number─────────────────────┐
│ Directory Number : 4552001 │
│ Entity Number : 1 │
│ Public Rerouting + False │
┌─Create: Teleservice filtering──────────────────────────────────────────────┐
│ Filtering parameters │
│ ISDN Teleservice + Phone │
│ Status + Day │
│ Filtering Index : 1111 │
│ Overflow Directory number : 2002 │
And what is the maning of A in the A2345 ,how did you configure it?Can you explain it ?
Return to “Translator”
