How many way to configuration direct line on E1-ISDN OXE
mrbi1310
Post by mrbi1310 »
Hi All
we have 100 phone with 01E1-ISDN connect to PSTN, and now my customer want to configuration direct line function, please help
For example:
- Lenth trunk: 0839766789 - 0839766888
- Extension: 6000 - 6099
If extension 6000 call out will display with 0839766789
extension 6001 call out will display with 0839766790
....etc
I have tried with entities function but not success, it is display with 08397667896000 (not correct) when i used extension 6000 for call out
Please help give me some ideal
Re: How many way to configuration direct line on E1-ISDN OXE
TG/NDD selector --> NPD number (?)
Translator/ ext.dialing plan/Numbering Plan Description - NPD (?) --> installation number, Calling DID id (?)
Translator/ ext.dialing plan/DID (?)/rules 0839766789 <-- 6000?
Trace "t3" - Calling number (when user 6000 make a call) = ?
mrbi1310
Post by mrbi1310 »
Hi Vad
i used with NPD 11
qReview/Modify: Trunk group NPD selectorqqqqqqqqqqqqk
x x
x Trunk Group ID : 1 x
x Instance (reserved) : 1 x
x x
x Public NPD ID : 11 x
x Private NPD ID : 11 x
x Management Mode + Expert x
x NPI Unknown NPD ID : 11 x
x NPI Data NPD ID : 11 x
x NPI Telex NPD ID : 11 x
x NPI ISDN Unknown NPD ID : 11 x
x NPI ISDN International NPD ID : 11 x
x NPI ISDN National NPD ID : 11 x
x NPI ISDN Reserved 1 NPD ID : 11 x
x NPI ISDN (User) NPD ID : 11 x
x NPI ISDN Reserved 2 NPD ID : 11 x
x NPI ISDN Reserved 3 NPD ID : 11 x
x NPI ISDN Reserved 4 NPD ID : 11 x
x NPI Private Unknown NPD ID : 11 x
x NPI Private Level 2 NPD ID : 11 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
lqReview/Modify: Numbering Plan Description (NPD)qqqqqqqqqqqqqqqqqqqqqqk
x x
x Description identifier : 11 x
x x
x Name : U_U_P_P_NDDI x
x Calling Numbering plan ident. + Unknown x
x Called numbering plan ident. + Unknown x
x Authorize personal calling num use + False x
x Install. number source + NPD source x
x Default number source + NPD source x
x Called DID identifier : -1 x
x Calling/Connected DID identifier : -1 x
x Installation number : 39766789 x
x Default number (num. inst. sup.) : ------------------------------ x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
For incoming call is OK, we used with DID and it is work fine but outgoing it is automatic addion extenion
Return to “Translator”
