Hi zanex
Which byte 3 CISCO sends to OXE? If it is 00 (Unknown/Unknown) then calling number from i/c call is just copied to o/g call setup.
OXE will take care of translating network numbers if byte 3 says "Private numbering plan" (09).
In all other cases, e.g., "Unknown" OXE will simply copy the number to outgoing call setup.
Also you should manage in local parameters of QSIG TG
Charge Calling And ADN Creation + YES
And manage an entity for QSIG TG with installation number to be appended to calling number.
See an example of my trace. Sbs on 2555 on i/c QSIG TG calls to T2 o/g TG with seizure prefix "9"
| (074939:000227) Physical-Event :
| long: 52 desti: 0 source: 0 cryst: 1 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 16
| IE:[18] CHANNEL (l=3) a1 83 98 -> T2 : B channel 24 preferred
| IE:[1e] PROGRESS_ID (l=2) 80 83
| IE:[6c] CALLING_NUMBER (l=6) -> 09 81 Num : 2555
| IE:[70] CALLED_NUMBER (l=2) -> 80 Num : 9
| IE:[7d] HLC (l=2) 91 81
| [95] Locking shift. codeset : 5
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (074939:000228) 1165: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 1 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP ACK [0d] Call ref : 80 16
| IE:[18] CHANNEL (l=3) a9 83 98 -> T2 : B channel 24 exclusive
| (074939:000229) 1165: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 51 desti: 0 source: 15 cryst: 1 cpl: 3 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 0f
| IE:[18] CHANNEL (l=3) a9 83 91 -> T2 : B channel 17 exclusive
| IE:[6c] CALLING_NUMBER (l=13) -> 00 81 Num : 78127552555
