4059 IP error
peceli
4059 IP error
Post by peceli »
I have just just installed a new 4059 IP keyboard following the procedure in the manual. All the configurations from the OXE is has been done precisely but when i run
OMniDesktop software i seem to have this problem.
Error A1-MO-S1
Appli : SBC Session
Msg: NOT USED
Status: L3OPEN, 12 protocol init failed
Machine specs :
Acer Veriton L480 PC
O/S : Windows 7 Professional SP1 32 bit, 4GB RAM, 100GB HDD
Have installed the driver of IP keyboard and OmniDesktop 4059 software version R5.3.4.
would really appreciate to solved this issue.
peceli
Re: 4059 IP error
Post by peceli »
Don't worry have finally fixed the problem.
Thanks.
murraya
Re: 4059 IP error
Post by murraya »
hi, it is best to share any findings as it will help others.
was it a second NIC on the PC that caused the issue?
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
got
Re: 4059 IP error
Post by got »
Hello
I have the same problem, can you tell me give the documentation for installation of 4059? how did you do?
I have the CD but I do not know how to install it as the installer of our OXE is gone.
Thank you for your help so precious.
Return to “Attendant”
