change users default password
fery_s
Post by fery_s »
hello every one
is there any way to change password for all directory numbers or specific kind of directories( for example sip extensions or 4028 ip touch)???
Re: change users default password
Through the 8770 probably, if you run a filter -> Export in Excel , modify in Excel , then re-import the files.
Or through the O2G Api if you know how to program.
Return to “Users”
