Call Routing Group
tgn
Call Routing Group
Post by tgn » 01 Dec 2012 11:41
Hello all,
i've been trying to build a simple configuration with the new Call Routing Group (CRG) feature.
there are 3 mobile 300 sets (301, 304, 334).
CRG 1 contains:
         ┌─Review/Modify: Call Routing Group ────────────────────────────────────────────────────────────────────┐
         │               Routing Group Number : 1        │
         │                               Name : test0                                                            │
         │                              Call Distribution                                                        │
         │              1st Extension Routing : 304                                                              │
         │              2nd Extension Routing : 334                                                              │
         │                          Routing group parameters                                                     │
         │                     Overflow Timer : 25                                                               │
         │             Overflow on voice mail + False                                                            │
The Prefix for CRG 1 is 337.
CRG 2 contains:
         │               Routing Group Number : 2        │
         │                               Name : test1                                                            │
         │              1st Extension Routing : 301                                                              │
The Prefix for CRG 2 is 307.
In Subscriber 301 is managed:
                          ┌─Review/Modify: Dynamic State User────────────────────────────────────┐
                          │                   Directory Number : 301                             │
                          │              Overflow on associate + True                            │
                          │           Overfl.busy to assoc.set + True                            │
                          │                 Associated Set No. : 337                             │
In Subscriber 304 is managed:
                          │                   Directory Number : 304                             │
                          │                 Associated Set No. : 307                             │
The Goal is:
If someone calls subscriber 301:
301 rings ---after busy or free set---> 304 rings ---after busy or free set---> 334 rings
If all sets are busy -> busy information must be sended in isdn protocol.
If someone calls subscriber 304:
304 rings ---after busy or free set---> 301 rings ---after busy or free set---> 334 rings
The problem at the Moment is... i'll get an incident if the sets 301 and 302 are busy.
02/12/12 15:21:05 000001M|---/--/-/---|=2:1724=Equipment in a loop, PC 0x08757ce0 neqt 1421 evt 10
incinfo GEA 1724
INCIDENT NUMBER:     1724
Network indicator:   Alcatel 4400
OBJECT CLASS:        Dhs3x_node
EVENT TYPE:          ProcessingErrorAlarm  (10)
PROBABLE CAUSE:      Unknown  (0)
SEVERITY:            Major
"Equipment in a loop, PC 0xP1P2 neqt P3 evt P4"
"P1 : Called function address, MSW"
"P2 : Called function address, LSW"
"P3 : Number of the active piece of equipment"
"P4 : Event number"
"This equipment is involved in a loop of events. It is stopped by"
"monitel in order to suppress the loop."
"The faulty half-communication, cleaned and released, is recovered by the"
"telephone application defence mechanism. The waiting logical events"
"are not processed."
"Note the incident with all its information on an observation sheet"
"(problem report), specifying if possible the error context.";
So i think there is a software issue here...
Also if i have trouble with only one simple CRG and all users are busy.
In this case allways ISDN Cause 41dez. (Temporary failure) will be sent instead of ISDN Cause 17dez. (User busy)
Is there anybody out there, who has expierience with CRG Feature?
Is there another solution to build such a configuration?
Thanks for all answers and regards...
mingtsoi
Re: Call Routing Group
Post by mingtsoi » 20 May 2013 03:25
Just use a virtual set associated to CRG prefix will be fine.
I'm still learning on the rope.
alexstreet3
Post by alexstreet3 » 17 Jan 2014 03:30
Hello everyone,
Someome can explain the difference between Huntgroup and a call routing group?
Thank you
Post by vad » 17 Jan 2014 04:03
Hunt group - this is usual group (with some parameters - search type, authorized camp-on calls % etc), you can dial HG number - from internal sets or from external, when dial HG numbers.
Call routing group - this is just like CDT table in entity.
alexstreet3
Post by alexstreet3 » 17 Jan 2014 04:51
Ok thanks for your Help Vad.
Now it's clear.
Have a good day
Return to “Groups”
