Re: Hunt Group forwarding to multi
Deleted by mistake the initial post from ricksterr.
Basically he wants to forward a call to a parallel hunt group to 3 external numbers.
Bad description and not much sense in it however:considering that 2000 is the HG number and it containing extensions 3000, 4000 and 5000.
However the hunt group seems to overide any forwards!
Normal behavior as documented in the sys doc.
Configure a ghost-Z extension. Configure 3 remote extensions 7001, 7002, 7003 (+3 remote ghost-Z sets 6001, 6002, 6003 --> see configuration for remote extensions in sys doc)
Configure the ghost Z extension in the overflow address of the hunt group (for internal calls). Configure ghost-Z as distribution for an entity that you will assign to the hunt group (for external calls overflow distribution).
Configure set supervision (of the ghost extension 6000) for on all 3 remote extensions and tick take supervision at off hook (7001, 7002, 7003).
You need license for 3 remote extensions (REX).
ricksterr
Post by ricksterr »
I will have a go at that, thanks for the reply, much appreciated...
ricksterr
Post by ricksterr »
we get "no remote extensions available" maybe license issue, is ther another way round?
Thanks for your help.
ricksterr wrote:Hi,
To ring 3 numbers outside the PBX in the same time... not really. Any other idea on this gents?
tot3nkopf wrote: Any other idea on this gents?
Ok I have one more:
Forward ghost-Z to a virtual number in the remote PBX and do the supervision part with ring there.
ricksterr
Post by ricksterr »
The other system is dumb (not a PBX as such), well there is actually 3 of them and we want them to be called at the same time. They are connected via DPNSS and just expect a call.
Hope this makes sense.
Return to “Groups”
