Elevator using UA VIRTUAL as call-groups
cowrea
Post by cowrea » 29 Aug 2016 07:54
Greethins,
i've got some configuration problems with my oxe.
I got an elevator, which has one single button.
If you push this button you will call a number.
This number is supervised by 2 people.
If both of them do not answer the call it will call an other number which is supervised by other peoples.
Numbers are:
elevator 100
number which the elevator calls 50
virtual number of the 1st two people 101
virtual number of the 2nd ten people 102
1st phone 1001
2nd phone 1002
3rd phone 1003
4th phone 1004
Well it works, but i got some confusing features.
After you push the button, the phone (1001 & 1002) will ring.
If one phone answers the call it could talk to the elevator, the 2nd will ring for eternity.
If you hang on the 1st phone it will ring for eternity, too.
You won't be able to answer the call once again.
You only got one try!
This is what i have configured:
lqReview/Modify: Usersqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x        x
x             Node Number (reserved) : 1                                       x
x                   Directory Number : 100                                     x
x        x
x                     Directory name : Elevator                                x
x               Directory First Name : Physical                                x
x               UTF-8 Directory Name : --------------------------------------- x
x         UTF-8 Directory First Name : --------------------------------------- x
x                      Location Node : 1                                       x
x                      Shelf Address : 1                                       x
x                      Board Address : 3                                       x
x                  Equipment Address : 7                                       x
x                           Set Type + ANALOG                                  x
x                      Entity Number : 1                                       x
x                       Set Function + Default                                 x
x                       Profile Name : ---------------                         x
x                       Key Profiles + None                                    x
x                  Domain Identifier : 0                                       x
x                        Language ID : 1                                       x
x        x
x                        Secret Code : ****                                    x
x        x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x                   Directory Number : 50                                      x
x        x
x               Directory First Name : number which is called                  x
x                      Shelf Address : 255                                     x
x                      Board Address : 255                                     x
x                  Equipment Address : 255                                     x
x                           Set Type + UA VIRTUAL (4035 VIRTUAL)               x
x                        Language ID : 1                                       x
x        x
x                   Directory Number : 101                                     x
x        x
x               Directory First Name : 1st helper                              x
x                        Language ID : 1                                       x
x        x
x                   Directory Number : 102                                     x
x        x
x               Directory First Name : 2nd helper                              x
x                        Language ID : 1                                       x
x        x
    lqReview/Modify: Dynamic State Userqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
    x        x
    x                Instance (reserved) : 1                               x
    x        x
    x                            Forward + Immediate forward               x
    x           Forward Directory Number : 101                             x
    x             Secondary Line Forward + No forward                      x
    x      Secondary Line Number Forward : ------------------------------  x
    x                     Do Not Disturb + False                           x
    x                               Lock + False                           x
    x                       Busy Camp-on + True                            x
    x              Overflow on associate + False                           x
    x           Overfl.busy to assoc.set + False                           x
    x                 Associated Set No. : 50                              x
    x               Reset Charge Counter + False                           x
    x           Consistent with Identity + True                            x
    x                          User Type + Administrative                  x
    x                   State of the set + In service                      x
    x             SIP Survivability Mode + None                            x
    x        x
    mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
    x        x
    x        x
    x                            Forward + Forward on busy and no answer   x
    x           Forward Directory Number : 102                             x
    x      Secondary Line Number Forward : 101                             x
    x                               Lock + False                           x
    x                 Associated Set No. : 9111                            x
    x        x
   lqReview/Modify: Progr.Keysqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
   x        x
   x                   Directory Number : 1001                             x
   x                            Key No. : 3                                x
   x        x
   x                           Function + Set Supervision                  x
   x     Mnemo (Pocket,Mobile,4040,8&9) : Elevator                         x
   x           UTF-8 Mnemo (8&9 Series) : -------------------------------  x
   x                       Ringing Mode + Long Ring                        x
   x                            No call + YES                              x
   x        x
   mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
How do i end this infinity calls?
Anyone got an idea?
Cowrea
Return to “Groups”
