List of numbers to be searched
Xero
Post by Xero »
hi all,
My customer has 4059 console, he wants to add some 2000 speed dialing numbers on OXE, all these numbers are external numbers nationwide so my customer want to search the list through dial by name using its console`s keyboard...i want to ask if it is possible to configure 2000 or more numbers in the systems speed dial with the name, so that these cumbers can be searched through the keyboard of 4059 console???
murraya
Re: List of numbers to be searched
Post by murraya »
yes it is possible, use speed dial by range and configure 2 ranges of 1000 numbers. add the speed dials and away you go....
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Speed Dialing”
