Pause in speed dials.
rob b
Post by rob b » 20 Nov 2009 07:42
Hi all how can I put a pause into the dialled number of a speed dial , the only options I have are 0-9, *# a,b,c or d, I need to make it easy for a user to change so want to avoid using ars if poss, thanks in advance
Re: Pause in speed dials.
Post by tot3nkopf » 23 Nov 2009 15:49
Can't think of any method. Look here:
viewtopic.php?f=118&t=6486&hilit=speed+dial+pause
You can use command tables for ARS programming.
swinstu
Post by swinstu » 06 Sep 2011 03:10
Does anyone know how to setup Pause in OXE speeddial ( direct abbreviated number).
I need to setup an international (this calls an IVR and asks for extension number after 20-25 seconds) so IDD number + 20seconds pause + ext number 222.
What is the permitted characters to make this work. I have tried * and # but no luck.
Any simple suggestions of solution. Alcatel docs have no information.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Return to “Speed Dialing”
