Phone book limit
ybelal
Phone book limit
Post by ybelal »
I have alcatel omni pcx enterprise, rel 7.1. Total user license in NMC is 24,000. Phone book limit is 2000x5, now i have reached that limit and whenb trying to create any new extension then i get an erroe message that too much entry in the phone book and can't create any new extension. I nned to crearte some new extensions. Is there any way to creat an extension without phone book entry or overflowing the phone book limit. Anyone advise me on that regards what to do please and that would be great.
Thanks.
I would imagine that you need to contact your sales person, and ask them a new license with more phone books items..
ybelal
Post by ybelal »
Is there any option/way to create an extension without creating phone book entry,please?
You can increase your phone book limits:
- edit hardware.mao file (OPS files) - item PARA_MAO 7.
- reinstall OPS (with new limits in hardware.mao).
ybelal
Post by ybelal »
Dear Mr. Vad
Thanks for your help, is that tampering safe?
Rens
Post by Rens »
Hello All,
You should also be able to update the value Vad is mentionining with cfgUpdate
(101)xa001001> cdmao
/DHS3data/mao
(101)xa001001> cfgUpdate
        Maximum values in the installation
           Users                                         :     1992
           1/2 com                                       :     3698
                Hit return to go on
These values depend on other parameters read in config.mao file
Users = Stations + Data Term. + Patients + 5(Substitution) + 150(HE-Minitel) + 10(Attendants)
Half-context = MAX (read value, calculated value)
         1 Stations                                     :      227
         3 Data terminals                               :     1000
         4 Patients (hospital) - Fictive users          :       25
         5 Trunks                                       :     1258
         8 Nodes in the network                         :      100
        10 Shelves (migration excluded)                 :        4
        11 1/2 com                                      :      256
        12 TS reserved for operators on INT/RT2 links   :        4
        13 Tables of R2 signalling translator           :     1000
        15 Data in R2 signalling translator             :     1000
        17 Abbreviated numbers                          :     4000
        18 DECT Handsets                                :      250
        19 Supervisable MCDU                            :     1500
        20 Number of Sub-Networks                       :       16
        21 Number of Network Set in Hunting Group       :      300
        22 Number of ARS route lists                    :      400
        24 Number of areas (accounting duration)        :     1000
        25 Number of Charge Scales (accounting duration):       30
        26 Supervisable Trunks / Trunk groups           :      150
        27 Number of Network Supervisor                 :        0
        28 Number of PIN                                :      100
        29 Number of CSTA buffer - Monitoring           :     1200
        30 Number of CSTA buffer - Pilot                :     1200
        31 Number of CSTA buffer - Service              :      500
        32 Number of CSTA buffer - RSI                  :     1200
        33 Number of CSTA buffer - Associate/Reference  :     1500
        34 Number of x25 command abbreviated numbers    :      100
        35 Number of called filter                      :      500
        36 Maximum Number Of Account Codes              :     2000
        38 Number of S0 users / bus on UA               :        8
        39 Number of entities                           :     1001
        40 Large number of fictive T0 (0/1)             :        0
Values read in hardware.mao file :
        41 Remanent size                                :    37134
        42 Stand-alone                                  :        0
        43 Number of BLF                                :        1
        44 Phone-book (x 2000)                          :        3
        45 SBC                                          :        2
        46 4635X                                        :        0
        47 4630                                         :        0
        48 4855                                         :        0
        49 Hotel accesses                               :        1
        50 ACD supervisor accesses                      :        0
        51 Set display languages                        :        4
        52 Maximum simultaneous casual conferences      :        0
        53 Large equipment capacity                     :        0
Value to modify (0 = Exit) :
Value 44 should be the value Vad is talking about. When updated you might need to reboot.
Don't forget to export the new OPS files and give them to your sales people. They need them for a new license purchase. Otherwise when you buy some new licenses and load the new OPS files your back to sqare one.
Rens
And if you do that in the cfgUpdade like VAD recommended, remember to do that on both CPUs if you have redundancy, and then reboot..
jasic
Post by jasic »
Before you can do cfgUdate you must go to path /usr3/mao
/DHS3data/mao or "cdmao" command -folder can be usr3 or usr6 - depends of partition used.
ybelal
Post by ybelal »
Great. Thanks a lot to every one here.
Return to “Phone Book”
