Entity : same plan , same prefix , different call routing
mike_[eu]
Post by mike_[eu] »
I use ARS. I 've same one numbering external plan . I use different TRK_GRP to route calls to different operators ( depend on prefix).
New task : I'd like to route call number (i.e. 060 ) to different TRK_GRP depends on extension like below ( see the clue ) :
1. ext_100 dial 060 > by TRK_GRP_1
2. ext_200 dial 060 > by TRK_GRP_2
but
3. ext_100 and ext_200 dial 061 > by TRK_GRP_2.
Should I divide " Omni and extensions " on Entities ? Buy how to say Omni call 060 to different TRK_GRP depend on extenion ?
Awaing Your ideas :).
Re: Entity : same plan , same prefix , different call routin
Several options. Among them:
1.
-use same config and configure two connection categories to be assigned to users: CC1 with access to TG1 and not TG2 and CC2 with access to TG1 and not to TG2
-use overflow in ARS for direction 060 to both TG1 and TG2
2.
-use 2 entities: ent 1 and ent 2
-configure two discriminators: entity 1 uses discri 1 and entity 2 uses discri 2
mike_[eu]
Post by mike_[eu] »
THX tot3nkopf . In the meantime I discover that's easy to use for me 2 entities ( maybe easiest to see what is made) . Thanks for response .
For number 060 (one discriminator, one route) - route with TG=-1, TG source=entity.
Users in Entity 1 and 2.
In Entity1 - TG number=1
In Entity2 - TG number=2
In this case - you will use one discriminator, one route but diferent TG (with the same dialed number).
Return to “Entities”
