Hi all,
I've a configuration with many entities in my OXE with the centrex feature.
I would like to activate secret identity for some users only.
I know that I can do that for all a entity but is that possible to do it per user instead ?
Thanks in advance for you answer.
M.b.
secret identity per user
Re: secret identity per user
there is a switch in mgr/users/dynamic state user
i think its field name was conform identity.
but take into account the the enduser can switch it back with the regarding translator prefix number if he has the right in his phone feat. cos
regards...
regards...
it works per user by creating a prefix and associate it to a programmed key. Doesn't work if you dial directly the prefix.
M.B.
M.B.
yep, right forgot to say...
regards...
regards...
