External call display addition extension
mrbi1310
Post by mrbi1310 » 18 Feb 2016 03:11
- We using entities for call outgoing display
- When i used agent 4004 take call out to my mobile phone number, on the mobilephone number display with 628445004004, it is addition 4004,
and on Entities configure as bellow, please advise
lqReview/Modify: Entitiesqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Entity Number : 0 x
x x
x Name : ENTITY_0 x
x UTF-8 Name : --------------------------------------- x
x Attendant Group Manager : -1 x
x Priority + NO x
x Emergency call to attd + NO x
x Traffic Overflow + Disallowed x
x Installation No. (ISDN) : 62844500 x
x Supplement.Install.No. (ISDN) : 62844500 x
x Caller ID Secret + No x
x AdvOfCharg2 requests (AOC2) + NO x
x AdvOfCharg3 requests (A0C3) + NO x
x Auto. Locking : 0 x
x Voice Mail Box No.for attendt : -------- x
x Trunk Group ID : 0 x
x External Callback Table : 0 x
x x
x Call Distribution x
x x
Please help
Thanks to all
mrbi1310
Re: External call display addition extension
Post by mrbi1310 » 18 Feb 2016 03:55
We used E1-ISDN, any body may help?
Post by cavagnaro » 18 Feb 2016 07:53
And what is the problem?
alexeik
Post by alexeik » 18 Feb 2016 10:30
i see one thing that might be wrong
in our entity its looks like
x Installation No. (ISDN) : 5223977 x
x Supplement.Install.No. (ISDN) : 0 x
the Supplement.Install.No. is as far as i know the extension which is used when there is no ddi for the extension
Post by vad » 18 Feb 2016 23:12
At first - show "t3" trace - what you see on mobile and what PBX send - may be not the same number
oldboy
Post by oldboy » 19 Feb 2016 01:42
remove the 4500 from the installation number and put 4500 in the Supp number only and re test
Post by vad » 19 Feb 2016 02:25
We can play with Installation/supplementary number but:
- we need to know NPD used in TG
- DID id and rules for installation/default number from NPD
- DID rules
- and need to understand - why we play with Entity 0 (usually TG) instead of Entity 1 (usually users)
mrbi1310
Post by mrbi1310 » 20 Feb 2016 23:02
i want to use Entities for call out display, i still tried to config
x Installation No. (ISDN) : 6284 x
x Supplement.Install.No. (ISDN) : 4500 x
on Entities 1 but same issue, it is automatic addion 4004, with 4004 is extension. We only want display with 62844500
Have you other way to cut 4004 when the call out? or other idea to solve this issue
Thanks to all
Return to “Entities”
