I do not know if my question should be in 'trunk groups' section, but it's basically the following.
Via ISDN trunks it is possible to send user data, for example using the 'call tag' parameter in CCS.
In the following example (T3 trace) to PSTN I use the string "ALCATEL_UNLEASHED".
| (260967:000002) 1624: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 76 desti: 0 source: 15 cryst: 1 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 53 27
| IE:[18] CHANNEL (l=3) a9 83 98 -> T2 : B channel 24 exclusive
| IE:[6c] CALLING_NUMBER (l=2) -> 00 a1 Num :
| IE:[70] CALLED_NUMBER (l=8) -> 81 Num : 199991
| IE:[7d] HLC (l=2) 91 81
| IE:[7e] USER_USER (l=27) 00 45 : CSTA
| [80] Correlator Data (l=19):
| 15 c0 41 4c 43 41 54 45 4c 5f 55 4e 4c 45 41 53 : '..ALCATEL_UNLEAS'
| 48 45 44 : 'HED'
| [47] Unknown type (l=255)
| [a1] Sending complete
But I cannot send this info if it is a SIP Trunk. Has anyone ever been able to send this information by sip trunk?
I have tested in several ways using asterisk's with OXE r10.
Both trunks (ISDN and SIP) have UUS in setup = true.
USER_USER in SIP Trunks
Re: USER_USER in SIP Trunks
It is possible from Release 11.1 only.
You have a new parameter in SIP/SIP External Gateway/CSTA User-to-User supported=True.
Returning to this subject, I already have access to version R11.1-l1.301, but I cannot send the user-to-user info in the sip header.
I've done a lot of testing and I do not see a way to put this to work. The 'CSTA User-to-User supported' parameter seems to do nothing.
Anyone been able to put this information in the SIP header? If yes, can someone post the configuration used?
Sorry did not mentioned it - Correlator data in UUS only supported in OTCS environment.
