OXE add digit to number
swat291
Post by swat291 » 21 Aug 2017 09:14
Could you please advise >?
Prefix number for OXE is 9
now for make extrenal call i need dial 9 9 ( and 7 digit number 1234567 )
where i can add one digit ( 9 ) between prefix and number?
Thanks in advance
tgn
Re: OXE add digit to number
Post by tgn » 21 Aug 2017 14:39
ars route...
its described im docs.
regards...
Gerry
Post by Gerry » 22 Aug 2017 03:56
In the route under digit to add, put the secondary 9 there
swat291
Post by swat291 » 23 Aug 2017 05:18
Thanks for quick answer!
I change setting is ars -
TRANLSATOR - ARS - 1 - ARS route list - - ars route - digits to add - 9
and after that when i dial 9 and 7 digits of landline - i hear voice
the number dialed is not authorized
if i dial 9 and 9 and 7 digits external call is ok.
i need to dial only 9 and 7 digits to call outside.
swat291
Post by swat291 » 23 Aug 2017 07:04
And also after configuring ARS my incoming calls from e1 TG stops on cisco router with error.
swat291
Post by swat291 » 23 Aug 2017 07:59
So ok.
now its working with ARS.
But now all incoming calls from e1 trunk group comes to OXE and forwarding back in trunk
I call 4272745 from land line
router convert this number to DID number 275 and send in trunk.
OXE see call from e1 trunk add 9 to number 275 and send - 9275 back in a trunk .
so its a loop until all channels in TG finish
Post by cavagnaro » 23 Aug 2017 11:11
ARS is for outgoing calls only, not incoming
Check your rules
Gerry
Post by Gerry » 24 Aug 2017 01:58
swat291 wrote:Thanks for quick answer!
If you hear the message the call is not authorized then you need to ensure the area is authorized in your access cos, assigned to the set doing the dialing and the rule defined in the discriminator rules, make sure you have a time based route list for your route.
swat291
Post by swat291 » 24 Aug 2017 07:00
cavagnaro wrote:
23 Aug 2017 11:11
Check your rules
Dear Cavagnaro ,
Could you please advise in which section i should search?
In Translator?
or Trunk Group settings?
or System settings?
i searched all forum and docs. no sense =(
Thanks in advance
swat291
Post by swat291 » 24 Aug 2017 09:10
Here is t3 trace
(1)dss38m_cpua> t3
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(530775:000001) MTRACER host (192.168.1.10, dss38m_cpua), version: R11.0.1-k1.520-32-b-no-c82
(530775:000001) MTRACER num: 004, time: 2017/08/24 16:45:48, loss: 0%
| (530960:000002) Concatenated-Physical-Event :
| long: 34 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 e1
| IE:[18] CHANNEL (l=3) a9 83 81 -> T2 : B channel 1 exclusive
| IE:[70] CALLED_NUMBER (l=4) -> 80 Num : 275
| (530960:000003) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP ACK [0d] Call ref : 80 e1
| (530960:000004) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 34 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 cd
| IE:[6c] CALLING_NUMBER (l=2) -> 01 81 Num :
| IE:[70] CALLED_NUMBER (l=5) -> 81 Num : 9275
| (530961:000005) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 80 cd
| IE:[18] CHANNEL (l=3) a9 83 82 -> T2 : B channel 2 exclusive
| (531111:000006) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 80 cd
| (531111:000007) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 e1
| (531161:000008) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 80 cd
| IE:[1e] PROGRESS_ID (l=2) 81 81
| (531161:000009) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 e1
| IE:[1e] PROGRESS_ID (l=2) 80 81
| (531281:000010) Concatenated-Physical-Event :
| long: 26 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : PROGRESS (03) Call ref : 80 cd
| IE:[08] CAUSE (l=2) 81 9c -> [9c] INVALID NUMBER FORMAT
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (531281:000011) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : PROGRESS (03) Call ref : 80 e1
| IE:[1e] PROGRESS_ID (l=2) 80 88
| (531414:000012) Concatenated-Physical-Event :
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 80 cd
| IE:[08] CAUSE (l=2) 82 9c -> [9c] INVALID NUMBER FORMAT
| (531414:000013) 1243: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 80 e1
| (531414:000014) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 00 cd
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (531414:000015) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 e1
| (531414:000016) 1242: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 e1
| (531415:000017) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 80 cd
Return to “Trunk Groups”
