SIP Trunk Group & External Callback Translator
smiths7
Post by smiths7 » 11 Oct 2017 11:30
How do I get a Trunk Group to use a Specific External Callback Translator.
I have a SIP Trunk Group going from OXE to AVAYA. When user calls from the AVAYA, the system uses the default translator and adds a 9 to the beginning of the 7 digit extension. I have setup External Callback Translator 99, with a DEF Rule and put it in the entity of the Trunk Group, but calls are still using the default translator.
Any ideas what I may be missing?
tgn
Re: SIP Trunk Group & External Callback Translator
Post by tgn » 12 Oct 2017 07:33
the callback translator defined in the called users entity is in charge here.
regards...
smiths7
Post by smiths7 » 12 Oct 2017 10:34
Is there a way to make any call coming in on a Trunk Group use a specific External Call Back Translator?
sadim
Post by sadim » 12 Oct 2017 12:27
Probably, the Country code of Callback translator assigned to the entity of the trunk is different from the country code of the callback translator assigned to the entity of the called user.
Return to “Trunk Groups”
