Hi all !
I've got 4 trunks in a trunk group.
Sometimes it happens that all of them remains ins state BUSY .
Is there a command that can force them to become free ?
I'm using 8770.
I remember I was able to do somethong similar in 4760 with a release command...
Regards.
Release busy trunks
Re: Release busy trunks
May be - reset coupler (board) - via telnet "rstcpl (shelf) (board)"?
Thank you.
I'm not very familiar with shelf and board (because I'm in a french context).
I'll try to find some info about that.
Regards.
Regards.
but why is ur lines getting busy. maybe ur busy tone detection is not working well
Hi morio.
Well I don't know about that.
Since then I moved this trunk group in a new one, using SIP instead of H323.
Don't have busy ones since then...
Think this topic can be tagged "closed" or "solved"
gatekeeper issue? can u post ur config
Hi haroun,
sorry for late answer.
As I mentioned before I made change to my installation.
So now I moved to SIP, I don't have thos problems anymore.
Thank you for trying to help !
ah ok good to know , u 're the welcomedascheltens wrote: ↑05 Nov 2019 03:31 Hi haroun,
bonne journée
