call accounting tickets over ethernet
diegod
Re: call accounting tickets over ethernet
Post by diegod »
Can someone help me ?
I Can not Extract the ticket files.
I can do it with winrar. But with 7zip, unrar,exe and unrar.dll can not.
I need a way to automatically extract these files.
Diego
C:\Documents and Settings\Dlf1bue\My Documents\Descargas\7za457>7za.exe t "d:\Tickets\Files\Not Processed\TAXATJZR.z"
7-Zip (A) 4.57 Copyright (c) 1999-2007 Igor Pavlov 2007-12-06
Processing archive: d:\Tickets\Files\Not Processed\TAXATJZR.z
Testing TAXATJZR Data Error
Sub items Errors: 1
C:\Documents and Settings\Dlf1bue\My Documents\Descargas\7za457>7za.exe e "d:\Tickets\Files\Not Processed\TAXATJZR.z"
Extracting TAXATJZR Data Error
Sub items Errors: 1
krzysioD
Post by krzysioD »
Because files were made using old (obsolete from many,many years) unix utility called compress.
It usually renamed compressed files to .Z (the Capital Z).
For Linux you need to search for ncompress-*.rpm, and for win32 any 'unix utilly pack' with [un]compress.
I've even been so kind to do your google-home-work and put it on pastebin. It should work on any win32 platform [tested even windows 98 SE], any if you have 64bit system is should also run without problems - but need to be tested.
viewtopic.php?f=47&t=5392
alex
Post by alex »
diegod wrote:...
But with 7zip ... can not.
Strange. :shock: 7-zip perfectly opens TAX*.DAT files in my case.
Kvantum
Re:
Post by Kvantum »
vad wrote:Whith accview command you see tickets in human form. retriev *.DAT file with ftp, unzip. you will see first string - #TicketVersion,1,5,L,CalledNumber,6,35,L,ChargedNumber,36,65,L,ChargedUserName,66,85,L,ChargedCostCenter,86,95,L,ChargedCompany,96,111,L,ChargedPartyNode,112,116,L,Subaddress,117,136,L,CallingNumber,137,166,L,CallType,167,168,R,CostType,169,169,N,EndDateTime,170,186,N,ChargeUnits,187,191,R,CostInfo,192,201,R,Duration,202,211,R,TrunkIdentity,212,216,R,TrunkGroupIdentity,217,221,R,TrunkNode,222,226,R,PersonalOrBusiness,227,227,N,AccessCode,228,243,L,SpecificChargeInfo,244,250,N,BearerCapability,251,251,N,HighLevelComp,252,253,R,DataVolume,254,263,R,UserToUserVolume,264,268,R,ExternFacilities,269,308,N,InternFacilities,309,348,N,CallReference,349,358,R,SegmentsRate1,359,368,R,SegmentsRate2,369,378,R,SegmentsRate3,379,388,R,ComType,389,389,N,X25IncomingFlowRate,390,391,R,X25OutgoingFlowRate,392,393,R,Carrier,394,395,R,InitialDialledNumber,396,425,L,WaitingDuration,426,430,R,EffectiveCallDuration,431,440,R,RedirectedCallIndicator,441,441,R,StartDateTime,442,458,N,ActingExtensionNumber,459,488,L,CalledNumberNode,489,493,R,CallingNumberNode,494,498,R,InitialDialledNumberNode,499,503,R,ActingExtensionNumberNode,504,508,R,TransitTrunkGroupIdentity,509,513,R,NodeTimeOffset,514,519,R
You see - field name, pozision.
What mean L, N, R it is Align or Field Type ?
Align.
L - from left position
Kvantum
Post by Kvantum »
vad wrote:Align.
What it mean ?.
Sample : #TicketVersion,1,5,L,CalledNumber,6,35,L,TransitTrunkGroupIdentity,509,513,R,StartDateTime,442,458,N
If L it mean i need get characters between 1 to 5 from start and if R i need charcters between 442 to 458 from end ?
Or it mean text aligment in the text field ?
12345(L) 12345(R) 12345(N)
0----    ----0    --0--
Kvantum
Post by Kvantum »
I think it not align. I think it field type. But where i can find specification for taxa format.
And can somebody help me. I need store in taxa reports incoming calls. How i can enable that ?
poposami
Post by poposami »
Hi ,I am looking for help on how to capture accounting tickets over IP.Its very urgent as we are going to setup
PMS for one hotel.so want to make tests.Need help in terms of documentation and tools for OXE r8.
Thanks in advance.
poposami wrote:Hi ,I am looking for help on how to capture accounting tickets over IP.Its very urgent as we are going to setup
Thanks in advance.
You need AHL over ethernet for PMS. In principle you don't need anything. The PMS must support this.
subva01
Post by subva01 »
hi ,
i have ftpeed the .DAT to my local box and renamed it to .zip and when i try to extract it i am getting following error msg .
"End-of-central-directory signature not found. Either this file is not a Zip file, or it constitutes one disk of a multi-part Zip file."
can you help me in finding the solution .
Return to “Application”
