call accounting tickets over ethernet
In my first answer I suggest rename file in *.z :lol:
endo
Post by endo »
yeah i know, i supposed that you typed wrong :oops:
vad wrote:In my first answer I suggest rename file in *.z :lol:
ALCATELMEX
Post by ALCATELMEX »
You`re Welcome...
Salu2...
jorgetorrescalvo
I am interested in capturing the cdr tickets via ethernet
Post by jorgetorrescalvo »
I would like to use the ethernet method that you mention. Could you provide me additional technical information ?
Is it necessary to buy some license in order to use this method?
Thank you in advance.
Jorge
j.torres@tecapro.com
endo wrote:great document, thanks a lot! this is exactly what i need.
if there is anyone interested with capturing the cdr tickets via ethernet from a 4400 pbx i can give some explanations about it.
thanks again.
ALCATELMEX wrote:Gracias Cavagnaro...
Annex the llink of the files that can serve you to understand and to interpret the positions of the ticket by ethernet. These positions you should interpret them in your program...
ftp://ftp.estratel.com.mx/pub/Ticket.pdf
ftp://ftp.estratel.com.mx/pub/Ticket.txt
"Save destiny as..."
Salu2...
roberto_DUP
Re: call accounting tickets over ethernet
Post by roberto_DUP »
Ok, i tried this procedure. But seems that i have a little problem.
The "Called Number" appears to be incomplete. Why?
Here's an extract of it, look at the "---".
#TicketVersion,1,5,L,CalledNumber,6,35,L,ChargedNumber,36,65,L,Ch
ED5.1045773119----                 5240
ED5.101921215----                  5240
ED5.1045222310----                 5140
ED5.101                            5013
My nightmare => R7.0-f4.401-13-mx-c6s2
Application/ Accounting you have ticket storage parameters where exist item "dialed number masked". Default value 4. You have 4 digits masked. Change to 0.
roberto_DUP
vad wrote:Application/ Accounting you have ticket storage parameters where exist item "dialed number masked". Default value 4. You have 4 digits masked. Change to 0.
Done!, thanx 8)
diegod
Post by diegod »
Hi Endo.
I need some help about connect and send and receive data via Ethernet.
May you help me ?
Thanks in advance
Diego
System documentation (red banner in the top right corner) - System doc./ Tech. doc/ General applications/ Accounting/ Internal accounting - Configuration procedure - Output on Ethernet.
You will find OPS locks, management in PBX and dialog (principle).
diegod
Post by diegod »
It is working now.
Thanks !
Diego
Return to “Application”
