agent logout .
agent logout .
Hi~~
I always supporting from all. thanks..
and I have question.
call center agent is login. and I want logout with IP phone.
actually, If I push the button( ex> #01 ) and agent number( 40001) and that agent status logout.
so I searching the prefix plan and suffix plan but i cann't the feature.
Can I this feature found ? or I cann't feature on ip touch phone.
pls answer the question.
thanks.
thanks.
- tot3nkopf
Re: agent logout .
Prefix plan-->Local features-->ACD prefix
Prefix + 1 : withdrawl (unavailable)
Prefix + 2 : wrap up
Prefix + 3 : supervisor call
Prefix + 4 : display queue
Prefix + 5 : log off
Prefix + 6 : log on
Prefix + 90 ;Agent Information
Prefix + 91 :State of private extension
Prefix + 92 ;Presentation Guide
Prefix + 93 ;ACR Management
Be aware that this is the status of CCD agent (agent from the PBX point of view).
Prefix + 6 : log on
Re: agent logout .
If you cannot find #01 - try to find #0 or #.
Re: agent logout .
thanks all.
but i know If 40002 agent ip phone is push the #0 + 5 (Logout) then 40001 agent status change logout status.
Can I do that ? I really want know about it.
certanly, I want know this.
Re: agent logout .
If you are trying to find the prefix either do a filter for #0 or Local Features¬ ACD Prefixes
Re: agent logout .
I would like to know the same thing. Is it possible to log off an agent from a supervisor set???thkim81 wrote:thanks all.
(I have seen that it is possible to deactivate skill of an agent.)
- cavagnaro
Re: agent logout .
No, you can't. That is why CCS exists.
Re: agent logout .
Thanks for your answer Cavagnaro.
I am not really familiar with Alcatel CC Solutions.
What do you mean by : "That is why CCS exists" ???
- cavagnaro
Re: agent logout .
CCS stands for Call Center Supervisor. It is a licensed software that is normally installed at least in one PC to configure and supervise your Call Center activities.
Re: agent logout .
Ok. It is claer. I looked for it in Business Portal and found the info about it.
Thanks for your help.
