How to config guest management in hotel
phukientongdai
Post by phukientongdai » 18 Aug 2016 00:30
Hi All
I have tried to config guest management but not sucessful, please help
1. Create Extension 1000 with IP phone (Hotel-Set Operation + Room and Use Type Of Dir. No. + Multi-occupancy)
2. Create 02 virtual analog phone with (Hotel-Set Operation + Room and Use Type Of Dir. No. + Guest) are 2000 and 2001
3. Application/Hotel/Static Link, i have done to link
Room Directory name : 1000
Guest Directory name : 2000
When i checkin, it is only help checkin with 2000 to Phone 1000, i want both 2000 and 2001 checkin to phone 1000 because we have 2 guest in the same room
Please help
phukientongdai
Re: How to config guest management in hotel
Post by phukientongdai » 30 Aug 2016 04:56
Any body can help me on this query???
oldboy
Post by oldboy » 30 Aug 2016 20:48
delete the static links, go in HOTMENU and assign them in there both sets to room 1000
phukientongdai
Post by phukientongdai » 13 Sep 2016 02:39
Who can help me guide some steps to config this
oldboy
Post by oldboy » 14 Dec 2016 18:49
Did you manage to do it!
Granville
Post by Granville » 19 May 2017 01:53
phukientongdai wrote:
13 Sep 2016 02:39
Were you able to get it done?
MichealFigueroa
Post by MichealFigueroa » 24 Jun 2018 00:39
13 Sep 2016 02:39
I'm also facing similar (almost) problem. Were you able to get some help or guide to solve your problem? If yes, will you be kind enough to share it?
I Found this Phenq testimonial very interesting
ThomasHadden
Post by ThomasHadden » 02 Sep 2018 18:59
18 Aug 2016 00:30
Hi All
Please help
Kindly update us that it's solved or not.
mustafa.ahmad
Post by mustafa.ahmad » 04 Sep 2018 05:02
You will need to create a suite and then add the two extensions .
At check in , both the suite extension will get checked in and also you can call the main suite number 1000 to ring both 2000 and 2001
EmilioNagao
Post by EmilioNagao » 01 Jan 2019 13:43
mustafa.ahmad wrote:
04 Sep 2018 05:02
Thanks for the explanation, was facing the same problem.
Return to “Application”
