Duplicate CDR
HUSSAINQCS
Duplicate CDR
Post by HUSSAINQCS » 07 Sep 2017 07:13
I have OXE integrated with third pary software call accounting softwareTMS and that TMS guy is telling oxe sending the duplicate cdr records
we have received duplicate call records from Alcatel, see a sample log for 05/09 , which is the root cause if issues.
05/09/2017 17:10:47 Rx <STX>K 7227 1 255 7227 1005092017170306 000029 0.00 65 60 144844444 2 01000000000000 00001000000000001 0044844444 0000000000050<ETX>
05/09/2017 17:10:47 Tx <ACK>
05/09/2017 17:10:48 Rx <STX>K 7227 1 255 7227 1005092017170306 000029 0.00 65 60 144844444 2 01000000000000 00001000000000001 0044844444 0000000000050<ETX>
05/09/2017 17:10:48 Tx <ACK>
05/09/2017 17:10:49 Rx <STX>K 7227 1 255 7227 1005092017170306 000029 0.00 65 60 144844444 2 01000000000000 00001000000000001 0044844444 0000000000050<ETX>
05/09/2017 17:10:49 Tx <ACK>
Is this really issue with MOXA ?
HUSSAINQCS
Re: Duplicate CDR
Post by HUSSAINQCS » 08 Sep 2017 06:41
Can anyone reply ?
Re: Duplicate CDR
Post by vad » 08 Sep 2017 07:23
in OXE - with accview command - do you see duplicated tickets?
Outputs in your post - from MOXA connection (not clear why you talk about MOXA - tickets looks like on-line accounting via Ethernet) or from accounting SW?
HUSSAINQCS
Re: Duplicate CDR
Post by HUSSAINQCS » 08 Sep 2017 07:31
with accview there is no duplicated tickets but in COM1 port of putty i
Re: Duplicate CDR
Post by vad » 11 Sep 2017 08:14
You use - only online printing or monitoring/tracking too?
HUSSAINQCS
Re: Duplicate CDR
Post by HUSSAINQCS » 11 Sep 2017 10:39
Tracking
HUSSAINQCS
Re: Duplicate CDR
Post by HUSSAINQCS » 11 Sep 2017 10:41
Sorry we are sending the data from MOXA to COM1 of Third party Call accounting software
Re: Duplicate CDR
Post by vad » 11 Sep 2017 23:38
Why you use tracking instead of real time tickets output?
HUSSAINQCS
Re: Duplicate CDR
Post by HUSSAINQCS » 12 Sep 2017 02:01
We are not using tracking please find the attached screenshot
Re: Duplicate CDR
Post by vad » 12 Sep 2017 02:45
HUSSAINQCS wrote:
12 Sep 2017 02:01
HUSSAINQCS wrote:
11 Sep 2017 10:39
Tracking
Return to “Application”
