Call forwarding not working with extensions ending with T
gulu
Post by gulu » 06 Apr 2015 03:46
Hi All,
I have a OXE (r 10.0) site with some extensions ending with T . When we try to activate call forwarding to those extensions ending with T it does not work . Is there any solution to this issue .
mustafa.ahmad
Re: Call forwarding not working with extensions ending with T
Post by mustafa.ahmad » 06 Apr 2015 04:04
Nopes , it does not work directly.
you can try assigning this T number to a speed dial number , and then assign that speed dial number in the forwarding .
Return to “Specific Telephone Services”
