Authomatic forward
LuisaLozanoT
Authomatic forward
Post by LuisaLozanoT » 24 Nov 2015 15:49
Good day,
I need to know where i can configure an automathic forward, this means that one extension forward to antoher in scheduled hours and days.
That´s possible?
Thanks.
Re: Authomatic forward
Post by cavagnaro » 24 Nov 2015 16:20
Not exactly
Maybe you can forward to an entity and there declare some rules.
Other option would be the use of ICS OneNumber but this needs a server and licenses as well.
Konstantinos.E
Post by Konstantinos.E » 30 Nov 2015 11:09
an other way is to make a script of mgr actions and add it to a crontab ?
good luck
Alca_holic
Return to “Specific Telephone Services”
