4059IP
godfreymbuyisa
4059IP
Post by godfreymbuyisa » 31 Aug 2011 02:28
This is a new installation;
1. The AL usb keyboard works fine
2. I can ping the CS
I get the 4059 IP error that there is a communication problem and what is the procedure of turning ON the tftp on the OXE?
Godfrey
swinstation
Re: 4059IP
Post by swinstation » 31 Aug 2011 03:55
did you set your operator ID in 4059 application(in program file /alcatel/setting) and also your OXE IP ADDRESS?
godfreymbuyisa
Re: 4059IP
Post by godfreymbuyisa » 21 Sep 2011 10:11
I have a problem about the ID, my route is program file/alcatel/AL 4059 applications.
I do not the settings route
muhammad hadi
Re: 4059IP Installation on Windoes 8.1
Post by muhammad hadi » 20 Jun 2016 01:43
Hi Support,
I am installing the 4059IP Attendant Console Application on the win 8.1.But Its not working as per the documentation, the compatibility is upto win 7 so any recommendation.
Please note that I am running of of the System with the same Application on windows 8.1
Waiting for response.
Muhammad Hadi
Markeberhard78
Post by Markeberhard78 » 20 Jun 2016 02:11
Hello Muhammad,
Per the doc, its supported upto win7. For win8 you need to install the EE that is extended edition.
Post by vad » 20 Jun 2016 04:19
muhammad hadi wrote:Hi Support,
Support ??? :o
muhammad hadi
Re: 4059IP
Post by muhammad hadi » 20 Jun 2016 04:31
Hi Vad,
Sorry I must have used guys/friends.Can you please assist me?
Waiting for your response
murraya
Re: 4059IP
Post by murraya » 20 Jun 2016 04:52
hi, 4059ip 5.4.1 is compatable win 8, 8.1 64bit accoring to tC1930ed02
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “IP”
