Ringback Tone Problem on SIP Ext GW Incoming Call
giovanni.attolini
Post by giovanni.attolini » 05 Sep 2017 12:44
Hello world!
I have a problem here with ringback tone on OXE.
Scenario:
                            /--PCM->  OPERATOR
ASTERISK  <-SIP->  OXE  <--
    ˄               ˄       \--T2-->  OPERATOR 2
SIP PHONE        IP PHONE
Situation:
Call from IP PHONE to OPERATOR 1 (PCM), RBT ok
Call from IP PHONE to OPERATOR 2 (T2), RBT ok
Call from SIP PHONE to OPERATOR 1 (PCM), RBT ok
Call from SIP PHONE to OPERATOR 2 (T2), RBT nok
So, only calls from SIP PHONE to OPERATOR 2 using T2 that you see this problem. I made a trace and the problem is that OXE doesn't send RTP packets until the called number answer the call, when you make a call you start hearing the destination speaker talking directly and the call remains mute until the answer.
Any sugestion?
Thanks for all.
Giovanni A. Attolini
Re: Ringback Tone Problem on SIP Ext GW Incoming Call
Post by cavagnaro » 05 Sep 2017 14:35
Sounds like an early media issue...which OXE version?
giovanni.attolini
Post by giovanni.attolini » 05 Sep 2017 15:06
Yeah!
CPU type : cpu82
Linux version : 76.20
Delivery software version : j2.603 ;
Patch version : 38 ;
MAO software version : J2.603.38 ;
Software Version Name : R10.1.1 ;
System Country : BRAZIL (35);
System for Large Config : no;
giovanni.attolini
Post by giovanni.attolini » 05 Sep 2017 15:40
Strange that occurs using T2 and not using PCM/R2.
enio.eltz
Post by enio.eltz » 06 Sep 2017 07:41
Could you post Wireshark traces of calls from SIP Phone to PCM R2 and SIP Phone to T2 capturing CS?
Did you check the trace when you have RBT with PCM R2? What does the OXE send? 180 or 183?
Best regards.
Enio Eltz Filho
ACFE OXE R12/R11/R10
ACFE OXO CONNECT R2
ACFE OXO R10/R9
Post by cavagnaro » 06 Sep 2017 07:43
Can you post the T3 logs as well? Could be a bad message from your operator...
giovanni.attolini
Post by giovanni.attolini » 11 Sep 2017 08:16
Attached are traces from CS: T3 messages and SIP messages.
Post by haroun » 25 Sep 2017 19:33
deep trace
tuner km
tuner ctr
trc i
tuner clear-traces
tuner all=off
actdbg all=off
tuner +at +tr +s +cpu +cpl hybrid=on
actdbg sip=on fct=on isdn=on abcf=on rtp=on
actdbg cnx=on voip=on
mtracer -ag -1 /tmpd/desinationfile -f 99 -s 4000000 -d&
giovanni.attolini
Post by giovanni.attolini » 25 Sep 2017 21:10
haroun wrote:
25 Sep 2017 19:33
deep trace
tuner km
tuner ctr
trc i
tuner clear-traces
tuner all=off
actdbg all=off
Ok, I will provide!
giovanni.attolini
Post by giovanni.attolini » 26 Sep 2017 12:40
Trace attached.
Sorry but I don't know where it ends.
Return to “SIP”
