SIP From Message
patmul39
SIP From Message
Post by patmul39 » 07 Nov 2017 03:58
Would anyone know why I'm seeing this in the FROM: part of the message (attached)? This might be the reason why the provider may be rejecting the OXE outbound calls.
sadim
Re: SIP From Message
Post by sadim » 07 Nov 2017 04:43
Perhaps the user 4421 has UTF8 caracters on his name. Try to remove it. If it solves, then thats strange, since UTF8 on sip is only since R11.1
patmul39
Post by patmul39 » 07 Nov 2017 04:59
It seems to be happening on all outbound calls for all users! I created a new user to test and that definitely does not have UTF characters in the name. This is quite strange. BTW - the OXE is still on release 9.1.
Thanks for your reply
Post by frank » 11 Jan 2018 10:15
did you solve this ?
Return to “SIP”
