Broadsoft integration international dialling problem
MartinB
Post by MartinB »
HI Guys
I have integrated an OXE OmniPCX Enterprise R9.1 i1.605.21 with a Broadsoft solution.
The first phase of the integration is for OXE calls to break out over the Broadsoft.
I can send all local calls without a problem, but when we try dial an international number the call takes too long to establish and then the OXE ARS overflows to my next route.
I am sending correct information to the Broadsoft as confirmed by their on-site support, but after certain time of approximately 4 seconds the pabx sees the trunk as unavailable and overflows.
Will this be a universal system timer I need to adjust or will it be a timer on the SIP settings somewhere?
I could not find any posts related to this specific problem before, if there are any please direct me.
thank you
Martin
Re: Broadsoft integration international dialling problem
Logs?
Configuration?
MartinB
Post by MartinB »
Sorry tot3nkopf didn't think logs were needed for this. But here they are. Thank you
Motortrace 3
TCPDUMP (Just the TCP stream extraction)
Tuner
Please let me know if you need any other config info like ARS or NPD or Network routing table etc
Martin
[[TRACES REMOVED AT THE REQUEST OF THE USER]]
MartinB
Post by MartinB »
Hi guys.
Does nobody have any idea why the calls overflow before the call can establish?
thank you
Martin
alex
Post by alex »
First, from motortrace you could see that OXE sends CANCEL because there were no messages received from the opposite side. Check with them why no messages are sent back.
Second, also you could try to Increase timer T310 in Trunk category of the SIP TG ( by default 31).
MartinB
Post by MartinB »
Thank you Alex. I really appreciate the feedback. I will test the Timer and also ask them why I am not receiving message.
thank you
MartinB
Post by MartinB »
Thank you Alex. T310 did the trick and it is working now.
Thank you for the response.
Martin
Return to “SIP”
