Hello everyone, I would like a help, someone would have some document that how to upload an 8088 device in OXE like SIP or NOE ???
I'm not finding anything related, please help this newbie,
How to configure 8088 in OXE
Re: How to configure 8088 in OXE
Not possible only 8082 can put in noe mode.
But in 12.1 MD1 should it be possible to load Android to 8088 and usw IP desktop softphone APP
Besteht regards
Gesendet von meinem A0001 mit Tapatalk
Besteht regards
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
I understand, I'm in Release 11.2 and I managed to upload the phones in SIP-DEVICE, is it possible to create the chief-secretary function on the device as SIP?
We are already planning to upgrade to Release 12.1 and use Android.
But I need to make it work in 11.2 with this function.
Thank you for your feedback.
Do you habe opentouch?
In opentouch there is an boss/sec function for conversation user
But I havnt used it only on try in training
No have opentouch.
is it a unique way to use this function in opentouch?
hi there,, hope this will help you.. i have made the doc using my lab system and works fine,,,
HOPE IT HELPS YOU,,,
Nice summary. I will give it a try following this guide. [emoji106]morio wrote:hi there,, hope this will help you.. i have made the doc using my lab system and works fine,,,
Enviado desde mi Redmi Note 4 mediante Tapatalk
Nevermind. I already downloaded it. LOL
i thought the file was private
Thank you!
Thank you!
