CDP protocol and Alcatel IPTouch 4018EE
Karik
Post by Karik »
Hello.
Could you please tell me why phones IP touch 4018 answer through CDP protocol with ip address 127.0.0.1. We have the following release - R11.2.2-l2.300-34-a-ru-c0
tgn
Re: CDP protocol and Alcatel IPTouch 4018EE
Post by tgn »
I think CDP is a Cisco specific protocol-extension to LLDP. You can try to disable LLDP in the 4018 phone set.
regards...
Karik - why you ask about CDP protocol - with ALU IP sets and HP switch?
alex
Post by alex »
OP just needs just one answer - ALU 4xx8/8xx8 sets do not support CDP, because it's proprietary protocol. They support LLDP.
That's all folks.
Karik
Post by Karik »
Thank you for your answers. I'll try to disable lldp.
Karik
Post by Karik »
But tell me please how can I do it. Need I connect to the phone by telnet session and which command shoud I use there?
tgn
Post by tgn »
telnet
help
try different lldp commands (like lldp set vlan off)
regards...
Return to “Alcatel-Lucent Series 8&9”
