Recover password for Ip Phones
aponterules
Post by aponterules » 18 Aug 2010 14:48
I have encryption working with the customer, but they don´t remember the password used for the phones, the one that is under
Encryption// Alcatel 8&9 series / IP Touch sets generic parameters
Review/Modify
Noe password : *
Confirm : *
So, I was wondering if it is possible to know that password
And if not possible, what would I need to do in order to set the new password, Do I need to reboot OXE and Thales boxes? or the new password would be sent to the phones without a reboot?
tailtwist
Post by tailtwist » 26 Aug 2010 05:01
showthread.php?4365-reset-4068-to-factory-default
Refer to this thread to remove/bypass the password
root
Re:
Post by root » 09 Apr 2011 19:34
tailtwist wrote:showthread.php?4365-reset-4068-to-factory-default
Not Found
The requested URL /showthread.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Eliott
Re: Recover password for Ip Phones
Post by Eliott » 14 Apr 2011 06:14
Why not enter a new one and reset the phone?
krzysioD
Post by krzysioD » 06 May 2011 14:14
Whhen phone is connected to a @CPU with encryption, it downloads the key, if you take the phone to the other site, with different key, then you need to go with a 'factory default' config. Anyway: it's documented in TC (and docs/training for security iirc).
Return to “Encryption”
