PCS - No login possible anymore after network fails
satolep
Post by satolep » 22 Sep 2010 14:07
Fellas,
We are facing some problems when the PCS assumes the MG. The role issue about pcscopy and recovery works fine until the day that the PCS is no more available to connect in anyway (mtcl, swinst, root), just returns the message "Login incorrect" and nothing else its possible.
We had this problem in several PCS from different places. R9.0 path 42a
Did someone faced this problem here?
Welcome to pcs_mg25
Alcatel-Lucent OmniPCX Enterprise
login: mtcl
Login incorrect
login:
Ralonso
Post by Ralonso » 24 Oct 2010 14:51
I have same problem with a PCS R9.0 path 34 anyone knows why is this problem?
Ralonso
Post by Ralonso » 25 Oct 2010 04:48
I find this is a issue reported here: crms00186501 Login incorrect on PCS H130129, solution is update to path 36
freedom
Post by freedom » 25 Oct 2010 11:00
If this issue was solved in patch 36, it should not be there in patch 42a.
But since it seems to be the same issue, I would suggest to raise an eSR, referring to the former case 'crms00186501'.
ether
Re: PCS - No login possible anymore after network fails
Post by ether » 29 Apr 2012 10:46
Having the same problem right now with R9.1 i1.605.21. Restarted the PCS machine (AS) and still the same. Anyone?
ether
Post by ether » 29 Apr 2012 11:23
I checked TC and a patch is required to correct this issue. Patch 25i (againnn). Appying a patch on 5 nodes is not so easy in my environment. :( bummerrrrrr
ether
Post by ether » 02 May 2012 09:49
Reformatted the PCS . After the scheduled pcscopy, someone might encounter this alarm;
30/04/12 03:30:01 000010M|---/--/-/---|=3:0433=PCS 10.20.10.11: Database update: error 5 info -1.
30/04/12 03:30:31 000010M|---/--/-/---|=3:0433=PCS 10.20.10.11: Database update: error 5 info -1.
01/05/12 03:30:04 000010M|---/--/-/---|=3:0433=PCS 10.20.10.11: Database update: error 4 info 4.
01/05/12 03:30:34 000010M|---/--/-/---|=3:0433=PCS 10.20.10.11: Database update: error 4 info 4.
Return to “Passive Communication Server”
