Passive Communication-Automatic Attendant
PME
Post by PME »
Hello Everyone,
How can we use Automatic attendant with Passive Communication Server?
Thank you.
Re: Passive Communication-Automatic Attendant
This is a nonsense question. AA is configured on main server. PCS has same configuration as main, so when it takes over AA should work.
PME
Post by PME »
Thank you Sir for your reply,
Sorry for the wrong question how does the automated attendant work, when the remote shelf (IP Media Gateway) lost the connection with appliance server?
The same as the AA is working on the main server.
One AA will work on main site (CS) - handling external lines in main site, one on the remote site (PCS) - handling local external lines. If you want to be able to reach extensions from both sides via AA you should configure private to public overflow (as the 2 sites are no longer connected via private link).
If you use AA on 4645 VM (and AS support 4645 VM) - on remote site AA will not works (no connection with AS, no connection with 4645)
PME
Post by PME »
Mr. Vad and Mr. Tot3nkopf,
Thanks for your reply.
Return to “Passive Communication Server”
