GD3 Don't work automatically on PCS
jpissot
Post by jpissot » 21 Mar 2013 06:38
On OXE R10 J1.410.40c.
There is a remote MG (with GD3) that is rescue by a PCS.
When the link between the MG and Main Call Server is lost, the GD3 don't reboot on the PCS, all the cards and phones are Out of service.
I reboot manually the GD3 (with the button) and the GD3 card is well connected to the PCS.
When the link betwenn the 2 sites is UP, the PCS reboot but the GD3 don't connect the main call server. I reboot manually the GD3 card (with the button) and the GD3 card connects to the main call server.
PCS Config
x Instance (reserved) : 1 x
x x
x Automatic update type + Daily x
x Reset type + Timeout x
x Database validity (in h) : 4 x
x Update time (hh:mm) : 03:00 x
x Reset timeout (in s) : 600 x
x
THank you for your help.
jpissot
Re: GD3 Don't work automatically on PCS
Post by jpissot » 26 Mar 2013 03:51
This problem is solved by replacing the GD3 card.
Return to “Passive Communication Server”
