Hi ,
Thanks for your reply , but how can get the pcinstaller tool and the docs for procedure as wéll.
Thanks in advance.
PCS Configuration Procedure
- cavagnaro
Re: PCS Configuration Procedure
From BPWS (seach the forum if you don't know what it is) and docs are available also in the forum.
Thank you cavagnaro, i will search for the forum and revert you back if necessary .
PC Installer included in SW delivery. If you have SW for PCS - you have PC Installer. For docs - ask your supplier (who give you SW)
