SNMP OID for T2 access supervision (OXE)
oliver0513
Post by oliver0513 » 06 Aug 2010 18:03
Hi all,
I would like to monitor how many channels were be used on T2 access and graph it with Cacti for example.
It's for Omnipcx enterprise, but i couldn't found anywhere the correspondant snmp OID to get it.
Any help ?
Thanks in advance.
Elandryl
Re: SNMP OID for T2 access supervision (OXE)
Post by Elandryl » 09 Mar 2011 02:59
Hi Oliver,
I'm sorry i don't have the solution but i'm looking for it too.
Did you find out which OID we need to look at ?
alex
Post by alex » 09 Mar 2011 04:15
This feature is available from Release 9.0 of OXE. Check whether it is your case.
Elandryl
Post by Elandryl » 11 Mar 2011 03:08
Exactly but i can't browse to find the OID myself.
I Can't add the A4400 mib to my snmp tools ....
Everytime there is an error :x
alex
Post by alex » 11 Mar 2011 08:33
[quote="ElandrylEverytime there is an error :x[/quote]
Did you configure SNMP parameters?
OID should start with 1.3.6.1.4.1.637
Elandryl
Post by Elandryl » 15 Mar 2011 09:53
I open a case and it's not possible ......
This feature was in the roadmap but well ... what kind of people using snmp supervision would supervise trunks ?
So they didn't had it ....
But we can make a snmp request to get the OXE version !
I was enjoying that they add snmp to the OXE but it seems i was wrong ...
You have to send a marketing request throught your respective channel partner, maybe they will add it.
alex
Post by alex » 17 Mar 2011 09:00
Elandryl wrote:This feature was in the roadmap but well ...
It is still there in the 9.0 course handouts.
But if you check MIBs - you would not find anything about TGs.
jpissot
Post by jpissot » 12 Apr 2011 09:08
Have you find the oid for T2 access?
My customer would like supervise his T2?
Elandryl
Post by Elandryl » 20 Jul 2011 04:21
In R9 it didn't exist, as Alex said it's in courses book, i found it there too..
It was supposed to be added but it wasn't, i'm looking to R10 doc to see if they finally add it !
Return to “SNMP Configuration”
