OID not working
jahjah
OID not working
Post by jahjah » 03 May 2011 05:12
In my company we've got some OXE 4400 to monitor them we use SP.
When i send a snmp commande on the OID to have the role of my PBX is not working
Here is the OID i talking about 1.3.6.1.4.1.637.64.4400.1.4.0
This OID is in the A4400-RTM-MIB.mib then when i try to browser this mib with my mib browser i got a error message
Impossible to browse this MIB
Can somebody know a solution for this issue?
Thanks a lot
alex
Re: OID not working
Post by alex » 03 May 2011 06:40
Do your OXE's run on 9.x SW? These OID appeared with 9.0 SW.
jahjah
Re: OID not working
Post by jahjah » 03 May 2011 09:42
Hi thanks you for your answer
I got to give more details about my architecture:
We working with 5 OXE
2 of them are on 9.x and the rest in version 8.x.
On OXE in 9.X 1.3.6.1.4.1.637.64.4400.1.4.0 (A4400-RTM-MIB) works but not the .1.3.6.1.4.1.637.64.4400.1.2.0 (A4400-CPU-MIB.mib)
On 8.x, according to you it would be normal for 1.3.6.1.4.1.637.64.4400.1.4.0 (A4400-RTM-MIB) not working.I'm OK with that.BUt i cannot understand why this one work1.3.6.1.4.1.637.64.4400.1.2.0 (A4400-CPU-MIB.mib) on the 8.x and not this on the 9.X
I hope you understand me
I am available for further information
jahjah
Re: OID not working
Post by jahjah » 10 May 2011 04:24
hi somebody can you please help
I really need help
alex
Re: OID not working
Post by alex » 12 May 2011 09:03
I checked on different releases. Yes the behaviour has changed. So only ALU can explain why it has changed.
Return to “SNMP Configuration”
